Application =========== Path and name: C:\Archivos de programa\EA6DDlog\EA6DDlog.Exe (32 bits) Size: 2,913,280 bytes Time from start: 0 hours 0 mins 1 secs Error occurred at: 04-05-09, 12:32:57 Error description: (DOS Error 2) DBFCDX/1001 Error de apertura: Log.dbf
Stack Calls =========== Called from: => DBUSEAREA(0) Called from: Source\Network.prg => NETUSE(32) Called from: Source\Utiles.prg => ACTVER(719) Called from: Source\Utiles.prg => (b)SETUP(511) Called from: .\source\function\MSGRUN.PRG => (b)MSGRUN(36) Called from: .\source\classes\DIALOG.PRG => (b)TDIALOG(86) Called from: .\source\classes\DIALOG.PRG => TDIALOG:DISPLAY(0) Called from: .\source\classes\DIALOG.PRG => TDIALOG:HANDLEEVENT(915) Called from: => DIALOGBOXINDIRECT(0) Called from: .\source\classes\DIALOG.PRG => TDIALOG:ACTIVATE(273) Called from: .\source\function\MSGRUN.PRG => MSGRUN(42) Called from: Source\Utiles.prg => SETUP(511) Called from: Source\EA6DDlog.prg => (b)MAIN(159) Called from: .\source\classes\WINDOW.PRG => TMDIFRAME:PAINT(2353) Called from: => TMDIFRAME:HANDLEEVENT(0) Called from: .\source\classes\WINDOW.PRG => _FWH(3333) Called from: => UPDATEWINDOW(0) Called from: .\source\classes\WINDOW.PRG => TMDIFRAME:ACTIVATE(936) Called from: Source\EA6DDlog.prg => MAIN(162)
System ====== CPU type: Intel(R) Pentium(R) 4 CPU 2.80GHz 2817 Mhz Hardware memory: 1024 megs
Free System resources: 90 % GDI resources: 90 % User resources: 90 %
Compiler version: Harbour 1.1.0dev (Rev. 10434) Windows version: 5.1, Build 2600 Service Pack 3
Windows total applications running: 41 1 M 2 Default IME 3 Menú Inicio 4 CiceroUIWndFrame 5 Descargas activas 6 TF_FloatingLangBar_WndTitle 7 ALSMTray 8 CL RC Engine3 Dummy Winidow 9 Actualizando base de datos 10 EA6DD Win Log 0.7.2 11 Connect: Hy-Gain DCU-1 12 Output 13 HamRadioDeluxe - [Logbook Entries] 14 Creando documento Adobe PDF 15 AcrobatTrayIcon 16 XTPTopLevelWndMsgNotifier 17 Help 18 Pleas, wait... 19 IconRestorer 20 {A7E495BF-9589-4a6e-8479-DDA2D8D3C05F} 21 PCSuite 22 SerLa 23 MCI command handling window 24 Nokia PC Suite 25 _XpDeviceWatchDog 26 Free Download Manager 27 DDE Server Window 28 4ec 29 QTPlayer Tray Icon 30 CDirectoryChangeWatcherHelperWindow 31 avast! UI Control Window 32 avast! Antivirus 33 OdiOlDVR 34 Device Detector 35 CtHelper32 36 Connections Tray 37 Medidor de energía 38 MS_WebcheckMonitor 39 aswServ helper window 40 BTTrayMainWindow 41 Program Manager
Variables in use ================ Procedure Type Value ========================== DBUSEAREA Param 1: O Class: ERROR NETUSE Param 1: L .T. Param 2: C "DBFCDX" Param 3: C "Log" Param 4: C "Log" Param 5: L .F. Param 6: L .F. Local 1: U Local 2: N 0 ACTVER Param 1: C "Log" Param 2: L .F. Param 3: N 1 Param 4: C "Log" Local 1: C "DBFCDX" Local 2: L .F. Local 3: L .F. Local 4: L .T. Local 5: N 1 (b)SETUP Local 1: U (b)MSGRUN Param 1: O Class: TDIALOG (b)TDIALOG Param 1: U TDIALOG:DISPLAY Param 1: O Class: TDIALOG TDIALOG:HANDLEEVENT DIALOGBOXINDIRECT Param 1: N 15 Param 2: N 0 Param 3: N 0 TDIALOG:ACTIVATE Param 1: N 4194304 Param 2: C "€ w A c t u a l i z a n d o b a s e d e d a t o s " Param 3: N 0 Param 4: O Class: TDIALOG MSGRUN Param 1: U Param 2: U Param 3: B {|| ... } Param 4: L .T. Param 5: U Param 6: L .T. Param 7: U Param 8: U Param 9: U Param 10: L .F. Local 1: N 0 Local 2: S Local 3: O Class: TDIALOG SETUP Param 1: C "Espere por favor ..." Param 2: C "Actualizando base de datos" Param 3: B {|| ... } Local 1: O Class: TDIALOG Local 2: N 237 (b)MAIN Local 1: O Class: TDIALOG Local 2: U Local 3: O Class: TBRUSH Local 4: U TMDIFRAME:PAINT Param 1: N 1661016051 Param 2: C "lB Ä°ý¬è¸¹ ŽU€¿ 0±ý§¿¬è¸¹" Param 3: O Class: TMDIFRAME TMDIFRAME:HANDLEEVENT Local 1: A Len: 5 Local 2: N 0 _FWH Param 1: N 15 Param 2: N 0 Param 3: N 0 UPDATEWINDOW Param 1: N 0 Param 2: N 15 Param 3: N 0 Param 4: N 0 Param 5: N 1 Local 1: O Class: TMDIFRAME TMDIFRAME:ACTIVATE Param 1: N 2687868 MAIN Param 1: C "MAXIMIZED" Param 2: U Param 3: U Param 4: U Param 5: U Param 6: B {|| ... } Param 7: U Param 8: U Param 9: U Param 10: U Param 11: U Param 12: U Param 13: U Param 14: U Param 15: U Param 16: U Param 17: B {|| ... } Param 18: U Param 19: U Local 1: O Class: TMDIFRAME Local 2: U Local 3: U
Linked RDDs =========== DBF DBFFPT DBFNTX DBFBLOB DBFCDX
DataBases in use ================
1: FRMQSL RddName: DBFCDX ============================== RecNo RecCount BOF EOF 1 3 .F. .F.
Indexes in use TagName
Relations in use
2: LIBROS RddName: DBFCDX ============================== RecNo RecCount BOF EOF 4 4 .F. .F.
Relations in use
Classes in use: =============== 1 ERROR 2 HBCLASS 3 HBOBJECT 4 TAPPL 5 TINTERNET 6 TFTP 7 TSTRUCT 8 TWINDOW 9 TCONTROL 10 TICON 11 TBRUSH 12 TMDIFRAME 13 TMENU 14 TMENUITEM 15 TMDICLIENT 16 TFONT 17 TMSGBAR 18 TRECT 19 TMSGITEM 20 TTIMER 21 TBITMAP 22 TREBAR 23 TIMAGELIST 24 TTOOLBAR 25 TDIALOG 26 TREG32
Memory Analysis =============== 358 Static variables
Dynamic memory consume: Actual Value: 709862 bytes Highest Value: 710232 bytes
